The Rail Path is on the exact opposite side of the corridor from where the Milton Line operates.
So it's not just another platform, it's many hundreds of metres of track realignment to go with it.
And then there's dealing with the neighbourhood who fought quite hard against Metrolinx for the Rail Path, as Metrolinx would have much rather not had the path in their way.
So yeah......that's a non-starter.
A couple of questions for you Dan. I'm not taking an advocacy position here, I'm just curious.
There appears to be surplus space in the current aerial photos on the west side of Bloor GO/Stn.
Pink is the property line, but I stopped drawing the distance marker where the visual indication of a building exists.
That distance is 7.5M from the edge of the existing track to the apparent building wall.
That should allow for one additional track and a somewhat shallow platform by my math.
Thoughts?
Second question, since I'm here picking your brain, which I apologize for doing a great deal today.......
What's the full build-out plan for tracks north/west of Bloor Station? I see 5 laid today:
The measurement from noise barrier to noise barrier is ~38M which, my math suggests would support up to 9 tracks.......certainly 8, comfortably, leaving room for gantry posts.
Finally, looking at the east side of the station (rail path), the City's ROW is ~9M or greater beside the station at all times, with a 2M buffer on the Mx side.
The minimum width of the path itself is for design purposes is 4M, assuming we allowed 5M for a space for lighting poles etc, and a 1M buffer beside the station, that provides 5 surplus M available with floating the path in the sky.
This section (below) is 12M, plus the buffer on the Mx side, but other parts are narrower:
If one had 5 surplus M, that would seem to be enough for an additional track w/o moving the platforms?
If this were the case, one needn't shift all the platforms over, one could shift some of the trains over, with Milton using the westernmost tracks, as it does today.
As noted, I'm not arguing for any of the above, of that its a good investment; merely that there seems to be space to do something there. But I appreciate there may be reasons that what 'seems' to be there is not actually available for said purpose.
