facepalming_brooklynite
Active Member
And why does the project require work at subway track level? I thought it's a pedestrian connection through an existing underground parking lotWhat's with the suits? Possibly asbestos here?
If I had to guess, it's because they're working underground NEAR the subway tunnels, and connecting to them within the station. Probably want to make sure nothing happens to the tunnels. It's just installation of "monitoring equipment").And why does the project require work at subway track level? I thought it's a pedestrian connection through an existing underground parking lot
In the Toronto West email from today they announced adding monitoring points to the subway tunnel.If I had to guess, it's because they're working underground NEAR the subway tunnels, and connecting to them within the station. Probably want to make sure nothing happens to the tunnels. It's just installation of "monitoring equipment").
Don't forget that when they were working on the Bloor GO/UP station a few years back, contractors drilled right through the subway tunnel from above, leading to some mud leaking in and a subway closure.
Tunnel construction begins at Bloor and Dundas
Work starts on a new connection giving riders a safe, accessible, seamless link between GO, UP & TTCwww.metrolinx.com
Construction has finally begun. The next question to be answered is, how long is this going to take?
Reading the comment about "600 transfers between the stations," makes it sound as if the connection will only be used by people transferring between GO and TTC.
What is this link telling us that the link above to the Metrolinx press release doesn't tell us.
It might even be possible that users of the Symington bus would be better off exiting the bus at Ernest Ave. and walking to the station instead of getting stuck in traffic between Symington/Bloor and the station. I look forward to trying that out.Reading the comment about "600 transfers between the stations," makes it sound as if the connection will only be used by people transferring between GO and TTC.
For residents of the Junction Triangle neighbourhood around Symington and Perth, this will become the preferred way to access the Dundas West subway station. So the tunnel will surely have thousands of daily users who going through the GO station to get to the TTC.
Also, 600 transfers happen now with the terrible transfer condition which isn't advertised at all.
Once this is built I imagine it'll be thousands of transfers.
One of those already happened and the other is under constructionA direct connection combined with GO and TTC fare integration would be amazing.
One of those already happened and the other is under construction![]()
