smallspy
Senior Member
There is enough variability to the running of the trains that you don't want to put in any permanent signage about which way to which trains. A sign pointing to the platforms, coupled with the electronic signage and announcements indicating which trains are stopping on which platforms is better suited to it.Why they aren't continuing the tunnel on the west side of the corridor both north and south is beyond me. At the same point that they connect the UP express platforms they could continue the path south to near Bloor and connect under the tracks at the same point north of Bloor the two UP Express Stations are connected. The signage could be GO trains left, UP trains right.
Considering the signage that Metrolinx has installed elsewhere, I suspect that the signage will clearly explain to people coming along Bloor that the appropriate way to the surface level TTC station is to continue along Bloor along their previously existing route, not to duck into the GO station.The even crazier routing is being in the UP express building at Bloor and asking how to get to the streetcar platformUp to the tracks, down the ramp to the GO platform, down the stairs to the tunnel, backtrack to the subway entrance, down the stairs the subway platform, walk to the other end of the platform, go up two flights of stairs and you are there. Oops, you forgot your sunglasses at the UP express station.
