Ziggy
Active Member
It's not hard to think of a mathematical model to demonstrate how this works. Then again, I'm sure this has already been done, and is probably on wikipedia.
Here's the wikipedia article about it: http://en.wikipedia.org/wiki/Braess_paradox
That's a very good point.
With regards to the use of highways, I suspect people endure a slow average speed on the highway as it is the better (relatively speaking) option. While you might only average 40 km/h, I suspect travelling along Finch or Steeles, or whatever, would yield an average speed much lower than that. Especially if you allow for innumerable traffic lights, construction, etc. Also worth considering is that for every day you get stalled in traffic on the highway there is the potential that the next day you might manage a faster time. Whereas with lesser roads, your travel time might be consistent but uniformly slower.
Yeah, that's probably true most of the time in reality, but if Braes's paradox is happening, then removing one of the linkages, say a highway, will actually result in a higher average speed, even with the same number of vehicles travelling through the network. As far as I understand it, it basically happens because of how the congestion balances out. If all the high-speed routes are connected together and become congested, then the whole network will jam up and everyone will travel at a slower speed. If the network is more disjointed, then each individual path through it will have to go through some slow bits, and some fast bits, but the overall average speed will be faster.
